Runbook-based Interactive Automation
NetBrain Runbook represents an automated workflow. It provides a visual way to codify a network troubleshooting process into an executable, reusable, and documentable workflow, to elevate collaboration efficiency. By leveraging Runbook, you can minimize the operations to create a troubleshooting flow. Besides, senior engineers can digitize their knowledge into a runbook template to streamline the best practices for the entire team.
Main UI Components
The main Runbook UI components are illustrated in the following diagram.
- Runbook Process Pane: Displays the workflow diagram in a Runbook.
- Runbook Result Pane: Displays the outputs of running the action nodes.
- Runbook Custom Notes Pane: Centrally displays information, such as notes, descriptions, annotations, runbook document, runbook template document, and device qualification in a single pane.
Main User Flow
A major Runbook use flow is documenting the troubleshooting activity and process. The use flow includes the following steps:
- Execute troubleshooting actions on a map.
- Insert another Runbook template.
- Continue troubleshooting and annotating the analyst results.
- Save the current Runbook as a Runbook Template.
Another main use flow is to create a Runbook from a Runbook Template, run the Runbook and share the results within your team.
Main Use Cases
The three primary scenarios of using a runbook are illustrated as follows:
Record Activities and Process
For example, end users run Qapps, execute CLI commands, or use Ping/Traceroute to troubleshoot a problematic area. These actions are instantly recorded in a personal runbook, and each action can be annotated with thoughts or analysis to document the diagnosis process.
Example: Execute a Runbook to Troubleshoot A/B Path Issue
Share Knowledge and Know-How
For example, to proactively take measures to resolve network problems that might re-occur, power users create a Runbook Template and continue to improve it, to share best practices and know-how with junior engineers.
Re-executable to Maximize Data Value
For example, Tier-1 engineers execute CLI commands to troubleshoot problematic devices on a map, document the diagnosis and escalate the issue by mentioning next-level users in the Runbook. Tier-2 engineers re-execute the Runbook, continue to add a Compare node to evaluate data changes between the two CLI outputs, and then escalate the issue to Tier-3. Each Tier can continue to build on top of what has been done previously by checking the analysis results and notes.
- Execute CLI Commands
- Retrieve Live Data
- Overall Health View
- Run a Qapp
- Run a Gapp
- Ping
- Traceroute
- Compare Network Data Changes
- Verify Application
- Run Network Intents
- Collect Configlet
- Automation Insight Node
- Use Guidebook to Organize Troubleshooting knowledge
- Runbook Document
