Runbook Document
NetBrain provides valuable data for network engineers, including automation results, troubleshooting guidance, network change records, and device inventory. You often need to present this information in clear, well-formatted documents. The Export to Word feature along with the Content Template Manager empowers users to create and customize multiple report templates, while AI tools transform report generation into a fast and one-click process.
How It Work?
Follow this simple workflow:
  1. Add a document node to your runbook.
  2. Select a content template that suits your audience or goal.
  3. Choose the data you want to export, like runbook steps or results. Then, refine the Word report with the AI Document feature by giving natural language instructions—such as “Add an executive summary before Section I” to quickly tailor it to your needs.
