Automation Insight Node
The Automation Insight node allows users to review the automation results of devices on the current map within a Runbook. This streamlines tasks such as network troubleshooting, assessment, and change management.
Note: To use this feature, relevant automations must be enabled in Insight Manager.
Main Use Cases
The Automation Insight node supports both interactive use for end users and structured workflow design for power users.
  1. End Users Add Insight Node:
    End users can add an Insight node in a Runbook to view the current map devices’ automation results.
  2. Power Users Templatize Runbook with Insight Node:
    Power users can create standardized workflows that includes an Insight node as a Runbook Template. This ensures consistent and reusable automation visibility across multiple use cases.
