Create a Map
The NetworkBrain system provides various ways to create a map according to different needs in different situations. The section lists all the ways to create a map.
Create a Map from Scratch
The basic operation to create a map is to create an empty map page from scratch, and then you can add devices, Extend Neighbors and add Auto Link on the map. When the map is created, you can improve your map as needed.
Additional Ways to Create a Map
In addition to creating a map in the Map application, you can generate maps while working with other system functions.
Improve Your Map
The system offers various ways of customizing a map, such as setting the style of a map, highlighting a map. You can enrich a map with the functions and tools listed below:
