Opening a Site Map
As soon as a site is created, the corresponding site map is generated by the system.
  1. Click Site on the taskbar to open the Site pane.
  2. Expand the site tree, right-click the target site and select Open Site Map from the drop-down menu.
  3. To browse more map pages on the site mapclick the page name and select another from the drop-down menu.
  4. Information Tip: The initial editing right of a site map is unclaimed. It will be granted to the user with the Site Management privilege who first opens the map and automatically be released once the user closes the map. You can also manually transfer the editing right to others.
    Graphical user interface
See Map Editing Rights for more details.
