2023-Nov-03-R11.1a
Understand NetBrain UI
NetBrain domain is a workspace as a digital twin of your network, as a subset of a tenant. For end users, the landing page of the domain is displayed as soon as end users login.
It includes the following UI common components:
Taskbar
The taskbar is located at the leftmost and includes the following menus.
IconDescription
Create a map, dashboard, runbook, data view template, Qapp, parser, Gapp, network change task, network intent or network intent cluster from scratch. See New MapNew DashboardNew RunbookNew Data View TemplateNew QappNew GappNew ParserNew Network ChangeNew Network Intent or new Network Intent Cluster for more details.
A picture containing icon
Description automatically generatedOrganize files and folders. See Manage Files for more details.
Description automatically generatedBrowse devices by Site, browse site details, and so on. See Site Pane for more details.
Description automatically generatedBrowse your network resources. See Network Pane  for more details.
Description automatically generatedBrowse and manage saved paths. See Path Browser for more details.
Graphical user interface, text
Description automatically generatedBrowse and manage runbook templates. See Runbook Template for more details.
Browse your Preventive Automation Dashboard. See PA Dashboard for more details.
Manage network changes in the system. See Manage Network Changes for more details.
Monitor and resolve device accuracy issues. See Manage Data Accuracy for more details.
Start Menu
Click the  icon on the top of the taskbar, and then you can access the main NetBrain functions. The start menu opens as follows:
Graphical user interface, text, applicationDescription automatically generated
Information Tip: You can click an icon to start the application or click the icon to pin the application to your desktop. And you can search the application from the search bar.
Desktop
Desktop is your personal space to organize your frequently used objects such as maps, device groups and applications and group them into a folder. You can also send file shortcuts or pin applications to the desktop for quick access. See Manage Desktop for more details.
Visual Search Bar
Use NetBrain's powerful search functionality to quickly find the objects in your domain, including devices, maps, paths, sites, and more. You can enter search keywords in the Visual Search Bar to search. See Search for more details.
Path and Trace Entrance
The Path is a frequently used feature in the NetBrain system. Click Path next to the search bar and enter the source and destination IP address to map the path between them. See Path for details.
The trace entrance is on the first layer of the top bar, and if you click Trace, a new traceroute node will be created in a runbook. You can use Traceroute to discover and map a routing path between two devices or between a Front Server and a device. See Traceroute  for more details.
NetBrain Support
You can click to contact NetBrain support. In the pop-up NetBrain Support window, you can file a new request to NetBrain Support or view the request history.
Incident Search Bar
The Incident Search Bar allows you to search incidents in the current domain. Enter search keywords in the Incident Search Bar to search incidents in the current domain. See Work on Incident Pane for more details.
Quick Access Toolbar
The quick access toolbar is located at the upper-right corner of your Thin Client.
Each icon and menu option on the quick access toolbar is described as follows:
IconDescription
Icon
Description automatically generated with low confidenceBrowse incident summary via Incident Quick Access, and you can also operate on a specific incident.
Icon
Description automatically generatedGet notifications for collaboration of map, incident, runbook, change management, dashboard, and function portal suggestion from your colleagues, such as sharing a map or dashboard and transferring editing rights of a map or dashboard.
Icon
Description automatically generatedGet notifications of events, such as errors and warnings in tasks and activities.
  • User Profile  — maintain your personal information.
  • Change Password — available only if you select the corresponding check box while adding or editing your User Account.
  • User Preference — you can set up User Preference to define the behavior of double-clicking a device and whether scrolling the mouse wheel to zoom in/out a map requires pressing the Ctrl key.
  • Log Out — the current user session will be ended.
  • Click Select Domain to go to more tenants and domains or create a new domain.
  • The hyperlink Domain Management is available only if you have the role of the domain administrator or the privileges of domain management.
    See  Create a Domain for information
Graphical user interface, application, table
  • Automation Usage: View the parameters of user login, triggered automation, interactive automation, preventive automation and intent execution. You can click Email Report to configure the email settings to get reports as required.
  • License Usage: view the licensed node count, consumed node count by device type and the licensed seat count. You can separately view the report about the max concurrent user logins for today, the last 7 days, and the last 30 days at the domain and system level.
Graphical user interface, text, application, chat or text message
  • Online Help: browse this Help.
  • Download NetBrain Smart CLI: download the Smart CLI tool.
  • About NetBrain: view the version number and legal notice.
