2023-Nov-03-R11.1a
Create Parser
The Parser is the foundation of many automation objects, such as Qapp, NI, DVT, etc. The Parser parses the variables you are interested in from the CLI command output, configurations, or API output.
The v10.0 adds the Visual Parser to allow users to create a Parser with no or little codes. The Paser in the prior versions is renamed as Advanced Parser.
Differences between Visual Parser and Advanced Parser
The following table lists the feature comparison between the visual Parser and advanced Parser:
| Feature Category | Visual Parser | Advanced Parser |
| Start/End Line | √ | |
| Text Replacement | √ | |
| Real-time highlight variable definition and comment | √ | |
| Line pattern syntax highlight and intellisense | √ | |
| Paragraph nested table | √ | √ |
| Paragraph nested paragraph | Multi-level nesting with parent line | Multi-level nesting |
| Supported Line Pattern Syntax |
| Supported variable types |
| Allowed ID lines | Multiple ID lines | Only one ID line |
| Supported Parser Type |
| Supported Data Type |
| Allowed Samples | One sample only | Multiple samples |
You can manage Parsers with Parser Library.
