2023-Nov-03-R11.1a
Understand and Manage Parser Library
You can view, add, edit, and manage all Parser files in Parser Library. There are three types of Parsers:
- Built-in Parsers — contains the pre-installed Parser files. This category is accessible to all users but can only be modified by system administrators.
- Shared Parsers in Tenant — contains Parser files accessible to all users in this tenant.
- My Parsers — contains Parser files only accessible to yourself. You can find your private parsers in all accessible domains under the current tenant.
Working with Parser Library
- Click the start menu
and select Parser Library. - Hover over a specific Parser and click the
icon to preview its description, qualifications, author, modified time, sample data, and variables.
- To create a Visual Parsre:
- Right-clcik My Parsers, then select New Folder and enter the folder name. A new folder is created.
- Right-click the new folder and select New Parsre to create your Visual Parser.
Note: You can also click Import Parser to import a Parser from your local disk.
- After defining a Parser, you can right-click it to do more if needed, such as renaming, exporting, and deleting.
