2023-Nov-03-R11.1a
Browse Network Objects and Context Map
The system can support various types of networks and provides built-in views for them.
Example: View the context maps of a firewall in a traditional network.
  1. Click Network in the taskbar. The Network pane is used to manage, organize and provide various views for network resources discovered from traditional networks and software-defined networks.
  2. In the Network pane, select Physical Network from the drop-down list and then select Device Type.
  3. Expand the Firewall folder and select a specific firewall.
  4. On the Context Maps tab, click Open Map to display the topology on a map.
  5. Click the Node Details tab to view its property and interface details of the firewall.
