The context menu may vary depending on the selected function category in the Domain Manager. Point to the target entries and click the
icon to select the menu options.
Function Category |
Context Menu |
▪View Edge Device Configuration |
▪Live Access Log |
▪Live Access Log |
▪Live Access Log |
▪Properties |
▪Generate Virtual Routing Table ▪Modify |
The following table describes the function of each context menu in the Domain Manager.
Option |
Add the selected devices to a group. |
Add the selected unknown sysObjectID to Vendor Model table. |
Remove the selected devices from the current domain. |
Delete the selected entries from the current table. |
Discover the selected IP addresses of devices. |
View the Shared Device Settings of the device. |
Open the full configuration of the source device. |
Move the selected IP addresses to the do-not-scan list. |
Export to CSV File |
Export the current list to a CSV file. |
