Create a Map
The NetBrain system provides various ways to create a map according to different needs in different situations. The section lists all the ways to create a map.
Create a Map from Scratch
The basic operation to create a map is to create an empty map page from scratch (see Create a Map From Scratch for more information), and then you can draw devices, Extend Neighbors and draw links (Auto Link) on the map. After the map is created, you can improve your map as needed.
Additional Ways to Create a Map
Apart from the common way of creating a map in the Map application, a map can be created while you are operating on other functions across the system.
Improve Your Map
The system offers various ways of customizing a map, such as setting the style of a map, highlighting a map. You can enrich a map with the functions and tools listed below:
