Using Runbook to Document Map-Based Activities
NetBrain Runbook provides a visual way to codify network troubleshooting process into an executable, reusable, and documentable workflow, to elevate collaboration efficiency. Besides, tribal leaders can digitize their knowledge into a runbook template to streamline best practices for the entire team.
Use Case
Record Activities and Process
For example, end users run Qapps, execute CLI commands, or use Ping/Traceroute to troubleshoot a problematic area. These actions are instantly recorded in a Default Runbook, and each action can be annotated with thoughts or analysis to document the diagnosis process.
Example: Execute a Runbook to Troubleshoot A/B Path Issue
Share Knowledge and Know-How
For example, to proactively take measures for network problems that might re-occur, power users create a Runbook Template and continue to improve it, to share best practices and know-how with junior engineers.
Re-executable to Maximize Data Value.
For example, Tier 1 engineers execute CLI commands to troubleshoot problematic devices on a map, document the diagnosis and escalate the issue by mentioning next-level users in the runbook. Tier 2 engineers re-execute the runbook, and continue to add a Compare node to evaluate data changes between the two CLI outputs, and then escalate to Tier 3. Each Tier can continue to build on top of what has been done previously by checking analysis results and notes.
Runbook consists of one or multiple assembled actions. Each action node can be executed individually and repetitively to automate data analysis. On a map, you can start quick automation with any action node first, and further save it as a runbook.
The following action nodes can be either executed independently or assembled in a runbook.
Action
Description
Run Qapp
Run a single Qapp to perform an automation task.
Overall Health Monitor
Run a built-in Qapp to monitor your network health.
Run Gapp
Run a group of contextualized Qapps for multistage troubleshooting.
Execute CLI Commands
Retrieve live data by executing CLI commands.
Retrieve Live Data
Retrieve device data by executing CLI commands or selecting built-in data types, and save the data.
Ping
Test the connectivity from one endpoint to another.
Traceroute
Discover and map a routing path between two endpoints.
Path
Refer to Mapping an A/B path.
Compare
Compare data changes between two different time points, or between two versions of device data.
Free Text
Annotate a text based on needs, such as describing the usage of each branch.
