CLI automation action is used to retrieve device data by executing CLI commands. This automation action is highly customizable, and you can execute different commands on different devices, not limited to the existing devices on a map.
1.On a map, select Execute CLI Commands from the right-click menu, or select Actions > Execute CLI Commands from the map toolbar.
2.Select the target devices. By default, this action applies to the existing devices on the map. To customize target devices, click the icon.
3.Enter the CLI command. By default, only one command can be executed at one time.
Tip: To bulk execute CLI commands, select Batch CLI, and click the icon to select Load CLI Templates. You can also create your own template, or select each device entry in the action panel to add or remove specific commands.
4.Click Run. After the execution is finished, you can click a device entry to view its output or execution log.
This is a sample result:
Tip: To save an action node and its input for reuse, point to it and click the icon to select Save as Favorite.
Retrieving Live Data
Data Retrieval Result
