This section introduces all the settings that you can configure to meet your needs when you customize a benchmark task.
Benchmark Settings |
Configuration |
Frequency |
Set the execution frequency for the task. By default, the frequency is only once. Note: To make sure that the task can be executed on-time, both the time settings on your machine and NetBrain Application Server (Web API Server) must be consistent with the Local Standard Time. |
Device Scope |
Specify the device scope to execute the benchmark task. ▪Select Device — applicable for physical network. oAll Devices — select all devices in the domain. oDevice Group — select devices by Device Group. oSite — select devices by Site. ▪Select External API Server — applicable for SDN network. Note: SDN is an add-on function that needs to purchase a license additionally. oCisco ACI — a configured server for retrieving the data of a Cisco ACI network. oVMware vCenter — a configured server for retrieving the data of a VMware vCenter network. oVMware NSX-V — a configured server for retrieving the data of a VMware NSX-V network. oCisco Meraki — a configured server for retrieving the data of a Cisco Meraki network. |
Retrieve Live Data |
Specify the data to be retrieved during the benchmark task, and you can set a threshold of the time limit for data retrieval. ▪Built-in Live Data — refers to the basic device data used to build your domain and topology, such as configuration files, route tables. ▪Path NCT Table — refers to the data tables parsed from live data and used to calculate paths. oIPsec VPN Table & NAT Table — only used for the CheckPoint Firewall. Note: Before retrieving them, go to Operations > Domain Maintenance > CheckPoint OPSEC Manager for configurations. oIPsec VPN Table[Real-time] & NAT Table[Real-time] — used for device types except for the CheckPoint Firewall. ▪Other NCT Table — other tables parsed from the live data. ▪Extend Data Collection — refers to data types for other usage. ▪Cisco ACI — contains data types used to discover and visualize a Cisco ACI network. ▪VMware vCenter — contains data types used to discover and visualize a VMware vCenter network. ▪VMware NSX-V — contains data types used to discover and visualize a VMware NSX-V network. ▪Cisco Meraki — contains data types used to discover and visualize a Cisco Meraki network. |
Enter CLI commands directly or add via templates to retrieve data by CLI commands. See Executing CLI Commands for more details. |
Additional Operations after Benchmark |
Build Topology — select to build topology after the benchmark task. The required data for building each topology type is as follows. Make sure that the corresponding data is selected in the Retrieve Live Data tab. ▪IPv4 Layer 3 Topology — requires configuration files and NDP tables (if there are IP unnumbered interfaces). ▪IPv6 Layer 3 Topology — requires configuration files and the IPv6 data in the Extended Data Collection category. ▪Layer 2 Topology — requires configuration files, ARP tables, MAC tables and NDP tables and the inventory information. Note: The accuracy of L2 topology relies on IPv4 L3 topology, so it is recommended to build them together during a benchmark task. ▪L3 VPN Tunnel — requires configuration files, GRE/IPsec VPN data in the Extended Data Collection category. ▪Logical Topology — builds topology for SDN network. It requires the Basic Data and Topology Data in the Cisco ACI, VMware vCenter, VMware NSX-V and Cisco Meraki categories. Note: The processes are order-sensitive. You can adjust the order by pointing to an entry and clicking the |
System Operations ▪Recalculate Dynamic Device Groups — recalculate the system device groups and device groups created via dynamic search. ▪Recalculate Site — recalculate the sites added via dynamic search in the Site Manager. The site topology and overview map will also be updated. ▪Recalculate MPLS Virtual Route Tables — recalculate Virtual Route Tables for the MPLS clouds configured with dynamical calculation. ▪Build Default Device Data View — update device data in the default data view. See Default Data View for more details. |
▪Rebuild Visual Space — select target Visual Spaces to rebuild for SDN. See Auto Updating ACI Data in NetBrain for more details. Note: Make sure that the IPv4 Layer3 topology option is selected in the Build Topology area. |
Parse Configuration Files — select parsers to parse specific data from configuration files. The data will be stored in the system for the usage of other functions, such as Instant Qapp. Note: Make sure that the Configuration File option is selected in the Retrieve Live Data tab. |
Update Maps — select the Enable check box of the map type you want to update, then click the corresponding hyperlink to specify target map files or folders. ▪Export to Visio — click Yes to enable the export of updated maps in Visio format, and click Browse to select a folder to store the exported Visio files, which can be in a shared network drive on Windows or in the Files pane. Tip: To configure the storage of historical Visio maps, click the To browse the details of the scheduled map updates, go to the Update Map Manager. To view the exported Visio maps, refer to Downloading a Visio Map. |
Summary |
Preview the settings you configured in the previous steps. |
▪Using Data View to Decode Network Design
