The following types of live device data can be retrieved for a task execution in a domain:
Note: The available data types may differ depending on the analysis task types and device types.
▪General Data Tables, including:
Route/ARP/MAC/NDP/STP and BGP advertised-route tables.
▪NCT Table, including:
Interface Information Brief, MPLS VRF, OSPF/BGP/EIGRP/PIM Neighbors, Multicast Route Table, NAT Table, Zone Table, and so on.
▪CLI Command Outputs
The outputs of the executed CLI commands. For example, the CLI outputs of the show ip bgp summary command or the show ip eigrp neighbors command.
