In the Device Details pane, you can perform the following actions with the configuration file for each device.
▪Browse and export configuration files in Current Baseline.
▪Retrieve configuration files from the live network. See Retrieving Live Device Data for more details.
▪Compare configuration files. See Comparing Historical Device Data for more details.
1.In the Device Details pane, select the Configuration File tab. The full configuration file of the device is displayed by default.
2.Select a technology from the drop-list to filter the configurations.
▪Opening the Device Details Pane
