The historical data of the following data types for each device is supported to be compared from the Device Details pane:
Take configuration file for example:
1.In the Device Details pane, select the Configuration File tab. The full configuration file of the device is displayed by default.
2.Click the
icon under the Configuration File tab. See Comparing Network Data Changes for more details.
▪Opening the Device Details Pane
