In the Device Details pane, you can perform the following actions:
▪Browse and export the CLI command outputs in Current Baseline.
▪Retrieve CLI command outputs from the live network. See Retrieving Live Device Data for more details.
▪Compare CLI command outputs. See Comparing Historical Device Data for more details.
1.In the Device Details pane, select the CLI Commands tab. The outputs of the first CLI command saved in Current Baseline for the target device is displayed by default.
Tip: The CLI command outputs saved in Current Baseline can be customized in a scheduled benchmark task. See Benchmark Task Settings for more details.
2.Select another CLI command from the drop-down list to navigate to its outputs.
▪Opening the Device Details Pane
