Data view can be categorized into the following types based on its availability:
▪Local Data Views — contains all the data views that are only applicable to the current map page containing the involved devices. It includes the following two types:
oActivity Data Views (
) — generated by executing automation actions on a map. The details of each activity data view can be browsed when you apply it on a map.
oMap Data Views (
) — generated by saving a data view within a map or sharing activity data views. The details of each map data view can be browsed in the Map Data View Manager.
▪Global Data Views (
) — contains all the data views that are applicable to any maps containing the involved devices in the current domain.
Example: Built-in Global Data Views generated by Built-in Scheduled Tasks.
See Multiple Ways to Generate Data Views for more details on how to generate an activity data view and a global data view.
Data view can also be categorized into the following two types based on the mechanism that the data is stored and displayed.
▪Static Data View — generated by running a Qapp or Instant Qapp for only once. Each data unit is single-valued.
▪Dynamic Data View — generated by running a Qapp or Instant Qapp periodically. Each data unit is vector-valued. After applying the data view on the map, you can click one of the data unit (int or float) to browse its trend during the running cycle in a line chart. See Overall Health Monitor for more details.
The following table lists all the tasks that can generate global data views and activity data views.
Data View Category |
Tasks |
Activity Data View You can share an activity data view as a map data view or global data view. See Sharing a Data View for more details. |
▪Apply a Data View Template on Map |
Global Data View |
