To save an activity data view as a local or global data view, you can share it as follow:
1.In the Data View pane, point to an activity data view and click the
icon to select Share.
Tip: To modify the default name of the data view, click the
icon.
2.Specify the data view category, Global or Local. A local data view can only be applied to the current map, while a global data view can be applied to any maps that contain the involved devices in the current domain.
3.Click OK.
