NetBrain domain is a workspace to separate areas, branches, or departments to simplify network management for an enterprise, as a subset of a tenant. The landing page of your domain is displayed as soon as you log in.
It includes the following parts:
The taskbar is located at the leftmost and includes the following menus.
Icon |
Create a map, dashboard, runbook, Qapp, parser, Gapp, or network change task from scratch. See New Map, New Dashboard, New Runbook, New Qapp, New Parser, New Gapp, or New Network Change Task for more details. |
Organize files and folders. See Files Pane for more details. |
Browse devices by site, browse site details, and so on. See Site Pane for more details. |
Browse your network resources. See Network Pane for more details. |
Browse and manage saved paths. See Path Browser for more details. |
Browse and manage runbook templates. See Runbook Template for more details. |
Manage network changes in the system. See Managing Network Changes for more details. |
Click the
icon on the top of the taskbar, and then you can access the main NetBrain functions. The start menu opens as follows:
You can click an icon to start the application, or click the
icon to pin the application to your desktop.
Desktop is your personal space to visually organize your frequently used map files, dashboard files and group them into a folder. You can also send file shortcuts or pin applications to the desktop for quick accesses. See Desktop for more details.
Use NetBrain's powerful search functionality to quickly find your interested objects in your domain, including devices, maps, paths, sites, and much more. See Search for more details.
Click Path to switch the Visual Search Bar to path calculation mode.
The quick access toolbar is located at the upper-right corner of your Thin Client.
Each icon and menu option is described as follows:
Icon |
Get notifications for map and dashboard collaboration from your colleagues, such as sharing a map or dashboard, and transfer editing rights of a map or dashboard. |
Get notifications of events, such as errors and warnings in tasks and activities. |
▪User Profile — maintain your personal information. ▪System Management (only for system administrators) — redirect to the System Management page. ▪Change Password — available only if you have the privilege to change your password. ▪Log Out — the current user session will be ended. |
▪Go to more tenants and domains, or create your domain. |
▪Get to know the licensed node count and consumed node count by device type, as well as the licensed seat count and the newly created objects in 30 days. Note: SDN licensed ports and CPU processors require additional purchase. ▪System Health — monitor NetBrain servers and services. It is available only when Service Monitor Agent is installed. See Monitoring Servers and Services for more details. |
▪Help — visit online help. ▪Contact NetBrain — reach out to Netbrain Support Team for help. ▪Support — redirect to NetBrain Website for further support. ▪About NetBrain — view version number and legal notice. |
