This section introduces how to create a network change task as well as the nodes and their functions involved in the network change task.
Tip: Before creating a network change task, ensure that you have sufficient privilege. See Access Controls for more details.
1.Click Network Change on the taskbar.
2.In the Network Change pane, click New Network Change.
Tip: The Network Change pane displays all network change tasks created in a domain.
3.In the New Network Change dialog, enter the task name, select a template and click OK. The Runbook pane opens. Then you can define the network change task node by node in the runbook.
▪Defining the Benchmark Before node
▪Defining the Benchmark After node
▪Adding and Defining a Change Note Node
4.Click the
icon to save the map. The network change task is saved in the map.
