NetBrain Parser is a file used to parse and extract key metrics (as known as variables) from command lines or device configurations for specific device types. The following section introduces the types and parsing methods of a parser.
The system provides the following types of parsers to parse data from different sources:
▪CLI Command Parser — define how to parse and extract key metrics from the outputs of a CLI command.
▪Configuration Parser — define how to parse and extract key metrics from configuration files.
▪SNMP Parser — define how to parse and extract key metrics from the outputs of an SNMP command.
▪API Parser — define how to parse and extract key metrics from an SDN network or third-party system via rest APIs.
The system provides the following parsing methods to obtain data based on the returned command or configuration format :
Parser |
Example |
Parse a single-instance data from a command line or configuration. |
show version |
Parse multiple instances of the same data as long as they are in the same data format in paragraph blocks. |
show interface |
Parse data from a table-formatted CLI command output. |
show ip eigrp neighbor |
Filter |
Filter out a segment of data from a non-standard and verbose output. |
filter EIGRP routing configuration |
Script |
Parse data by using Python scripts. |
Version $ver |
For more details on how to choose a parsing method when defining a parser, see Selecting a Parsing Method.
