This section introduces the mandatory steps only and you can explore Elements of a Qapp for extensive applications.
1.Click the
icon from the taskbar and select New Qapp from the drop-down menu.
2.Specify the device input in the Start node.
3.Double-click the Canvas node to enter the Canvas tab page.
4.Specify the device pattern in the Device Queue. See Defining Device Queue for more details.
5.Define device branch in the Device node.
6.Select a parser to parse variables in the Command node.
7.Select variables and define the table node.
8.Define outputs to analyze the variables. For how to define outputs, see Output for details.
▪Creating a Qapp to Monitor Network Health
▪Creating a Qapp to Check Device IOS Version
