The Start node indicates the starting point of a Qapp. You can define how to obtain devices at runtime within this node for a Qapp.
There are three ways to obtain devices:
Mapuse objects such as devices, paths, sites or device groups on the map where the Qapp runs as Qapp device input at runtime.
Calculated Pathuse a path as Qapp device input. It is required to define and calculate a path at runtime.
Tableuse a predefined global table as Qapp device input. As a result, the Device From option in the Device Queue node can only be a table.
