Device Queue is a group of input devices waiting for a Qapp to loop.
At this node, you can define the pattern to load input devices into the Device Queue:
Deviceloads devices in a single device pattern and each device is an independent individual in the Device Queue.
Neighbor Pairloads devices in pairs and each pair contains two devices in neighbors. This Device Queue pattern is often used to compare a device and its neighbor's difference, such as MTU and Duplex mismatch.
Pathloads devices in hop pattern. This Device Queue pattern is often used in Qapps to troubleshoot path problems.
Tableloads devices from a specified table.
Defining a Device Queue Node
1.Click the Device Queue node on the Canvas tab.
2.Select the device input from the Device Input drop-down list. There are four options as follows:
Device
Neighbor Pair
Path
Table
3.Extend the next node for the Device Queue node based on your needs. For how to extend nodes, see Extending a node for details.
Output
Device (such as this, nbr, prev, and next, which can be extended depends on the settings you selected in step 2).
Next nodes:
Device
Command
Table
