The Output node is used to specify how to present the analysis result of the Qapp.
Example: Three types of Output nodes for various usage.
Defining an Output Node
You can extend one or more Output nodes in the workflow based on your needs. For how to extend nodes, see Extending a node for reference.
There are the following three types of outputs:
Basic output
Script output
Monitor output
Qapp table
Running a Qapp
