The Device node (as known as this node) is extended from the Device Queue node. It is used to specify on which device column of the device queue the Qapp will execute the downstream command node.
1.Click the
icon on the Device Queue node and extend a Device node.
Note: The device can be this, nbr, prev or next, depending on the settings you selected in Device Queue.
2.Modify the name in the Node Name field if necessary.
3.In the Select a device column drop-down menu, change the device column from the Device Queue node if necessary.
Next node:
