Parser Library is used to store and manage built-in parsers and customized parsers. A parser in Parser Library can be directly used to retrieve and parse data in other modules.
1.Click the start menu
and select Parser Library. The Parser Library pane contains the following three categories by default:
▪Built-in Parsers — contains the pre-installed parser files. This category is accessible to all users but can only be modified by system administrators. It includes the following four types of parser files:
oCLI Command — used to parse data retrieved via CLI commands.
oConfiguration — used to parse data from configuration files.
oSNMP — used to parse data retrieved via SNMP commands.
oAPI — used to retrieve and parse data from external systems or SDN controllers via rest APIs.
▪Shared Parsers in Tenant — contains parser files that are accessible to all users in this tenant.
▪My Parsers — contains parser files that are only accessible to yourself. You can find your private parsers in all accessible domains under one tenant.
2.Point to a parser file and click the
icon to preview it.
Further operations:
1)Point to a folder in the left pane, click the 2)Rename the folder directly. |
