Creating a Qapp to Check Device IOS Version
You can use the built-in methods in the basic output node of a Qapp to analyze and display data, such as highlighting a map, drawing a map, defining an alert, exporting a CSV report.
In this section, a Qapp will be created to check device IOS version. For the devices with versions meet the predefined conditions, the Qapp will draw and highlight them on a map.
Complete the following steps:
1.Create an Ordinary Qapp
2.Define Canvas to Retrieve and Parse Data
3.Define Analysis and Output
