1.Click the
icon from the taskbar and select New Qapp from the drop-down menu.
On the Execution Flow tab, Start and Canvas1 nodes are created.
2.Click the Start node and in the Define Qapp Device Input field, use the default option Map. It means that the Qapp takes all devices visible on the map and runs independently on each device.
3.Double-click the Canvas1 node to enter the Canvas editor.
