Run Golden Intent
You can execute each individual member intent or encapsulate all the golden intents into a wrapper intent and execute. The member intents in the left pane are the cloned intents from golden intents.
- Run a member intent: You can execute each individual intent and view its results.
- Golden Check: All the intents will be encapsulated into a wrapper intent and the diagnosis tree will be displayed.
- You can Schedule this intent or define its execution settings.
- You can also save the current intent to map intent and common intent.
Execute a Member Intent
The execution result of an intent closest to the selected time point on the timeline will be displayed in the right side pane. To execute a member intent, select an intent and click Run.
Golden Check
To execute all the currently displayed member intents, click Golden Check and:
- All the intents will be encapsulated into a wrapper intent and the diagnosis tree will be displayed.
Click Run to execute the golden check.
- The wrapper intent will be named ‘Golden Check N’. It can be viewed in the drop-down menu:
To edit the wrapper intent, go to
menu located next to Build Dashboard in the right side pane and choose Edit Intent.
- There is an intent diagnosis block that contains a diagnosis.
The displayed member intents are treated as follow-up intents.
