Intents in Network Intent Manager
In Network Intent Manager, all intents are categorized into the following groups. You can select a group and click OK to view its intents.
- Standalone Intent: All standalone intents are displayed by default.
Note: The intents in the built-in Recommended Templates folder can be used as template for creating Map/Path Intents. - Common Map Intent: The common map intent is at the map page level, meaning a single common map can have multiple associated intents.
- Site Map Intent: A container site map may also associate with a map intent.
- Device Group Map Intent: You can create intent based on device group map, and each device group map can have only one associated intent, which shares the same name as the device group.
- Path Intent: All path intents are stored in the Path Intent category. A path can have multiple built-in path intents with different names.
