Common Operations in Network Intent Manager
All operations you can perform on an intent item are listed in the right-click drop-down list.
Two major operations are explained in detail below:
  • View Intent:  You can open and view intent in one of the following ways:
    • Directly click the intent item in the left pane to open and view the intent in View Mode.
    • Point to an item from the intents listed in the left pane and click Open to view the intent in View Mode.
    • Click Open Intent from the right-click drop-down list of the target intent item.
  • Open Diagnosis Tree: Click Diagnosis Tree from the right-click drop-down list of the target intent item.
Information Note: The operations of viewing the intent and open Diagnosis Tree can be performed on other types of intents in the same way.
The following table describes the operations that can be performed from the drop-down menu of an intent.
Tab in the Drop-down Menu of an Intent
Description
Open Intent
Open the intent in View Mode.
Diagnosis Tree
Open the Diagnosis Tree of the intent.
Rename
Modify the curremt intent name.
Edit
Edit the intent in Edit Mode.
Delete
Delete the intent from the Network Intent Manager.
Copy Path
Copy the Path of the intent to clipboard.
Move To...
Move the intent to another folder in the Intent Manager.
Export
Export the intent to your local computer.
Save As
Save the intent as a new intent with a different intent name.
Intent Replication Wizard
Open a wizard to guide you to complete many definitions in one UI.
Auto Intent Wizard
Open a wizard to guide you to enable an intent template for auto inten.
