Elements of a Qapp
The fundamental element of a Qapp is called a node. Each node contains specific attributes and connects logically.
Example: Nodes in a Qapp Editor
Nodes in the Qapp Editor
The Qapp Editor has two types of tabs:
- Execution Flow tab — define the execution sequence of the nodes within a Qapp, as well as the relations or conditions among the nodes.
- Start — the starting point of a Qapp. You can define the way of the Qapp to obtain devices at runtime within this node.
- Qapp Description
- Global Table
- Filter Criteria
- Input Variables
- Canvas
- If-condition
- Stop — the endpoint to terminate a Qapp. You can define a message and the message will prompt when the Qapp executes this node.
- Canvas tab — contain an internal workflow composed of multiple subnodes as follows.
Context Menu of Qapp Editor
The context menu in the Qapp Editor is as follows:
Icon | Description |
![]() | Save the Qapp. |
![]() | Save as another Qapp. |
![]() | Run the Qapp. |
![]() | More operations, such as customizing functions and locking the Qapp. |
Built-in Variables in Qapp
The following table introduces the system built-in variables in a Qapp.
Variable Name | Description |
$_device | A global PyDevice object representing the device on which the Qapp is running. It is a simple PyDevice object and not an array of PyDevice objects. The Qapp automatically loops through each of the selected devices. |
$_device_queue | A variable representing the device queue table that the Qapp loops through. |
$_command | The command on which the output is based. |
For more built-in variables, refer to the Global Data Repository (GDR).
