If-condition
The If-condition node is a decision node, representing a test on the variables of a global data table from the Table Input or from the previous Canvas node. Different branches will be executed after the If-condition node depending on the test result (true or false).
Defining the If-condition Node
  1. In the Qapp Editor, extend an If-condition node first under the Execution Flow tab.
  2. Click the icon on the If-condition node. The following dialog prompts.
  3. Select a node for True and select another one for False individually. Click Extend.
    This is a sample workflow:
  4. Click the IF node in the workflow to configure the detailed settings.
    1. Enter the name and a description of the node.
    2. Specify the statement type of setting the conditions:
  • Basic — select the variables of table attributes from the drop-down list and set conditions.
    Information Note: Only applicable to the Canvas node which has attributes in the Global Data Table nodes.
  • Advanced — enter the script manually. See Python scripting for reference.
