If Conditions
General Condition Structures
The general Python syntax for a simple if statement is as follows:
if condition:
    Indented code blocks
If the condition is true, then the indented code blocks are implemented; if not, then the indented code blocks will be skipped.
The result of an if condition is a boolean type of value, and its legal value is either True or False. Bool is short for boolean in Python.
Comparison Symbols
The simplest condition is to compare two variables. The following table lists the comparison symbols of all the usual arithmetic.
TextMath SymbolsPython Symbols
Less than<<
Greater than>>
Less than or equal to<=<=
Greater than or equal to>=>=
Equals===
Not equal!=!=
For example:
$var1 > 90
$var1 > $var2
($var1 - $var2)/($var3-$var4) > 1
And you can use and or or operators to combine two simple conditions. For example:
$var1 <90 and $var1>80
$var3 == 1 or $var4 == 1
Information Tip: All the system built-in variables can be compared with None. For example:
$var1 is None
$var1 is not None Same as " var1 != None", the returned result is True if $var1 has a value, otherwise, return False.
$var1 is not None
Information Note: A single equal sign (=) is not used to check for equality in Python. Use the double equal sign (==) instead.
