Qapp Description
The Qapp description refers to a summary of the basic information about a Qapp.
Adding Qapp Description
  1. In the Qapp Editor, click the icon on the Execution Flow tab. The Qapp description is displayed in the bottom pane.
  2. Enter the required information in each field.
    1. Enter a description to describe the Qapp in the Description field.
    2. Enter a keyword in the Keyword field as a hint.
    3. Enter the contact information in the Contact Info field.
  3. In the Sample Picture field, click Import to select a sample map or a picture from your local folder to visually describe the Qapp.
