Qapp Center
Qapp Center
Qapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Qapp files.
  • Built-in Qapps — contains the pre-installed Qapps. This category is accessible to all users but can only be modified by system administrators.
  • Shared Qapps in Tenant — contains Qapp files that are accessible to all users in this tenant.
  • My Qapps — contains Qapp files that are only accessible to yourself. You can find your private Qapps in all accessible domains under one tenant.
Working with Qapp Center
  1. Click the start menu , go to Map-Based Automation section and then select Qapp Center.
  2. Point to a Qapp file and click the icon to preview it.
    Information Note: You can also right-click a Qapp and select Run it as a Runbook node.
