Create a Qapp
Proceed to the steps below to create a Qapp to reference the created API parser and define outputs to analyze the data.
- Click the
icon from the taskbar and select New Qapp from the drop-down menu. - Double-click the Canvas node to enter the Canvas editor.
- Select API at the Command node.
- Select the API Parser you have created.
- Click the
icon, select the data and push into the Table node. Define the output, such as highlight. For more details about how to create a Qapp, see Creating a Qapp. - Save the Qapp.
