Visualize Third-party API Data via Qapp
You can call third-party API data in the system and monitor the parsed data on a map by running a Qapp.
- Open a map with your interested devices.
- Right-click on the blank space of the map and select Run Qapp.
- Select the Qapp you have created in the Select Qapp dialog.
- Run the Qapp. Sample output is as follows:
