Create an Advanced API Parser
An API Parser defines how to retrieve and parse data from a third-party system. Before you define an API parser, you need to understand what data needs to be pulled from the third-party system and the corresponding API to query the data. For information about how to define API parser, see API Parser in Visual Parser.
