Triggered Intent
In Preventive Automation Manager, you can view, edit or delete the preventive automation.
Click
, scroll down and select Preventive Automation Manager from the menu.
Navigate to the Triggered Intent tab of Preventive Automation Manager. All installed Intents are listed here.
Send Email column: You can enable/disable the email alert.
- Click the desired entry under the Send Email column.
- In the Send Email window, enable the Enable email notification when the Network Intent has alerts checkbox.
Enter the email address(es) to receive the notification.
Trigger Event Template column: Whether to enable trigger event template when the Network Intent has alerts.
- Click the desired entry under the Trigger Event Template column.
- In the Trigger Event Template window, check in the box to trigger the event Template whenever the NI has alerts.
Select the event template.
- By default, an event template Default_Preventive Automation Incident is activated.
- To select another event template, click the event template Default_Preventive Automation Incident to open the window Select Event Template with a list of event templates. Select the event template> Click Save.
Automation Name column:
- Click the desired entry under the Automation Name column.
- A Configure Preventive Automation for Intent window will pop up, you can modify the probes and other settings. Refer to Intent Library for more details.
View Preventive Automation History
Click
- Navigate to the Triggered Intent tab of Preventive Automation Manager.
In the Last Modified Time column, select the desired automation and click
. Select View History in the drop-down list.
See Also:
