Delete Installed Automation
To delete an intent in the Preventive Automation Manager:
Click
, scroll down and select Preventive Automation Manager from the menu.
- Navigate to the Triggered Intent tab.
Select the desired automation. In the Last Modified Time column, click
- Click Delete from the drop-down list.
Note: After the above steps are completed, the deleted triggered Intent (s) will not be displayed in the Execution Tree. However, the triggered Intent itself will not be deleted from the system. |
