Create a Dashboard
The Dashboard visually displays multiple reports in different charts for a specific purpose.
Through Dashboard, you can have an effective method to tell what happens in the network. For example, whether Boston office’s network has a problem, or whether all WAN links across the entire network are running well. With the key metric trends of the network displayed, you can also perform trend analysis.
Main User Flow
- Select a Report
- Define Chart
- Define Call-out
- Repeat step 1-3 to add more widgets, and adjust the layout of the widgets
- Save Dashboard
