Manage Dashboard
In the Dashboard Manager, you can view and manage all the dashboards.
Click the start menu
, and select Intent-Based Automation > Universal Dashboard (alternatively, you can directly click
from the Taskbar to open Dashboard Manager).
- Select the desired dashboard, click
and you can:- Open the dashboard
- Move the dashboard to another folder
- Save as
- Rename the dashboard
- Delete the dashboard
- Export the dashboard to a local folder
- Select the desired folder, click
and you can:- Create a subfolder
- Create a new dashboard within the folder
- Rename the folder
- Delete the folder
- Import one or more dashboards into this folder
