Manage Report
In the Report Manager, you can manage and view all the reports.
Click the start menu
, and select Intent-Based Automation >Report Manager.
Hover over the desired report, click
and you can:
- Edit the report
- Move the report to another folder
- Save as
- Rename the report
- Delete the report
Export the report to a local folder
- Hover over the desired folder, click
and you can:
- Create a subfolder
- Create a new report within the folder
- Rename the folder
- Delete the folder
Import a report into this folder
