View Path Log
You can view logs for the A/B path in two ways:
  • Instant Log  – Displays real-time log data immediately after path calculation.
  • History Log  – Shows saved log records from previous path calculations.
View Instant Path Log
After you calculate a path, the path flow diagram is displayed. To view more information, click any hop or Path Detail to view the device log, traffic state, relevant data, and execution log.
Information Tip: Upon any path issues, you can quickly submit problematic paths to NetBrain with one click. To do so, click the  icon in the Path Result Pane and select Contact NetBrain.
Component
Description
Operations
Path Flow DiagramDisplay each hop along a path.
  • Click the icon to switch the path direction for the path flow diagram and the path on the map page.
Note: The icon is only displayed when you calculate a two-way path.
  • Click a device icon to view its device log or traffic state. And the device is also located on the map page.
  • Click the icon to switch paths if there are multiple load-balanced paths.
  • Click the L3/L2/Overlay Stack to show the path hop details of this path type.
Device LogDisplay technologies evaluated on each device during path calculation.
Click a device icon in the path flow diagram to browse the device's log under the Device Log tab. Or click the icon or the icon to browse the device logs in order.
Tip: By default, the Only show steps matched with the device checkbox is selected to hide the technologies that the system failed to evaluate or that do not exist on the device. You can clear the checkbox to view all technology evaluating steps.
Relevant DataDisplay relevant data which is used for path calculation.Choose the 'CLI command' or 'Data Table' tab to view the raw CLI data or parsed data table.
Execution LogDisplay execution steps recorded with time stamps.Click the icon to expand execution log; click the icon to collapse execution log.
Traffic StateDisplay the emulated traffic state reflecting the real transfer traffic status and used to find the next-hop device along the path, but that is not the real traffic state of your live network. All data is generated via show commands and user inputs.By default, the traffic state is not displayed. To view the traffic state of the path, click the Traffic State tab.
View Historical Path Log
To view the log of a saved path:
  1. Click Path on the taskbar.
  2. In the Path Browser, click the number in the History column of the target path entry. A floating box prompts to display all history results of the path by timestamp.
  3. You can select which history path you want to show on a map.
  4. Double-click the Path entry in Path Browser to open the Path results pane.
  5. You can also check more History results.
