Document Path
Document all key applications while the network is healthy. Enter all application endpoints and gateways into the system by importing a CSV file or manually adding them through the user interface.
While the network is functioning properly:
Discover the application paths.
Define Network Intents (NI) for each application.
Document each path using the following options:
