Add Path Descriptions and Notes
Follow these steps to document the path and add notes for each hop:
  1. Edit the path description
    1. In the Path Details > Path Logic pane, click the pen icon.
    2. Enter a description that explains the purpose or context of the path.
  2. Review the raw data and check results for each hop in the path.
  3. Aadd Notes to record observations or findings for each step in the path calculation.
    Notes you create are shared with other users who view the same path.
